changeing gears
mulcher
06-13-2004 22:40:07
We are wanting to change our WD6 gears to slow it down. The JD creeper gears are killing us. I think we have as much power or close to it but with them low gears they just keep going. I believe an M has the same transmission but runs taller tires and goes about the same speed. That transmission in the WD6 and short tires should slow it down. My question. Is the difference in the trans or the final ratio in the rear?
Brian
FARMALL
06-14-2004 06:00:54
 Re: changeing gears in reply to mulcher, 06-13-2004 22:40:07
Its in the ring & pinion gears.
ChadS
06-14-2004 09:28:53
 Re: Re: changeing gears in reply to FARMALL, 06-14-2004 06:00:54
So if you can put in the ring and pinion from the W series in the M, and H, to speed em up,, can you do the opposite use the M in the W series, would that slow down the W series tractor? Chad
mulcher
06-14-2004 18:34:16
 Re: Re: Re: changeing gears in reply to ChadS, 06-14-2004 09:28:53
Chad
Do you have a W series you want to slow down too?
I haven't had the cover off of the rearend so don't what I would be getting into.
Brian
ChadS
06-15-2004 09:43:48
 Re: Re: Re: Re: changeing gears in reply to mulcher, 06-14-2004 18:34:16
If you do this, you are looking at tearing down the entire final drive assembly, axles and housings too. you will have to remove the top plate, then the bull gears and axles, then the brake assembly, then there is 2 bearing holders that are bolted into the rear end housing, they are shimmed, so keep them together, that will remove the pig, when you remove the 2 holders. the pinion shaft,, you will need to tear the top shaft out of the tranny, and replace it with the M shaft,, good time to check bearings and seals a this point... Hope this helps,,, ChadS
FARMALL
06-14-2004 16:21:08
Yes, the w4 will fit in the H and speed it up like wise you can put an H ring and pinion in a w4 and slow them down. Same thing with the M and W6. Hope this helps Farmall
WILDMAN
06-15-2004 04:20:28
 Re: Re: Re: Re: changeing gears in reply to FARMALL, 06-14-2004 16:21:08
WONDER HOW MUCH OF AGAIN THERE WOULD BE WITH SUPER H TRANS?
LW
06-15-2004 05:17:07
 Re: Re: Re: Re: Re: changeing gears in reply to WILDMAN, 06-15-2004 04:20:28
I don't remeber the ratio but there is a O-4 down here that has a different first gear , its tag extra low first gear, the rind and pinion is about like the difference in the oliver's.
Flogger
06-15-2004 06:08:41
 Re: Re: Re: Re: Re: Re: changeing gears in reply to LW, 06-15-2004 05:17:07
I think the orchard tractors O-4 and O-6 did have a creeper low gear. About 1.5 MPH.
