M motors with no sleeves
jason
06-13-2004 11:13:00
i have considered pull ing the sleeves out of my motor and having some custom pistons made. What kind of durability do these motors have and about how many ponies. I also thought about having some stroke added to the crank while i was at it. Thanks for any suggestions
FARMALL
06-13-2004 13:17:57
 Re: M motors with no sleeves in reply to jason, 06-13-2004 11:13:00
Cars & trucks run in the block and some tractors. I have some 'M's that has run in the block for 7 years now and never touched. The tractor pulls in 2 clubs points classes 5500, 6000, 6500, 7000 & 7500. 4.375 bore in a 264-281 block. 248 block can go to 4.250 bore. If you are going to work your tractor in the field I wouldn't run in the block. I use Arias pistons and have them made to order.
Hope this helps Farmall
jason
06-14-2004 17:47:47
 Re: Re: M motors with no sleeves in reply to FARMALL, 06-13-2004 13:17:57
what do you have to do to the block and did you change piston design?
