Burns
John
12-12-2001 20:46:22
I see they took the other posts off. I don't know why people want to mess things up for everone else. Do you have a opinion on the other question about the airflow through the venturi? I just can't understand if the venturi is smaller then the intake runner how can making the ports bigger help? Is there anyone with a venturi as big as the intake runner? Is this possible? Any opinions would be appreciated without any bashing please.
G Taylor
12-13-2001 07:47:11
 Re: Burns in reply to John, 12-12-2001 20:46:22
It's a matter of proportion, the venturi size vs. airflow requirements & port/valve size. While the pressure drops & velocity increases through the venturi the velocity drops & pressure returns to almost what it previously was afterwards. As for airflow restriction the valves, ports, manifold turns/kinks offer more flow interruption/restriction than air straight through the carb restriction/venturi. Better a wee bit small on he carb venturi loosing a couple of percent peak HP. By mid track she's lugging & mid range torque is more important. If lugged down at the end a strong booster signal & well atomized fuel in proper proportion will pull farther than a "Mega" carb that is out of it's ideal airflow range.
OK, But...
12-18-2001 11:32:26
 Re: Re: Burns in reply to G Taylor , 12-13-2001 07:47:11
Where did you get this infomation? It sound good to me, but have you tested different size ventuies on a dyno? Are you pulling a Deere? Would it be the same for a 4 or 6 cylinder motor? Would a zenith carburetor act different than a marvel schebler with bigger venturies?
G Taylor
12-18-2001 19:45:58
 Re: Re: Re: Burns in reply to OK, But..., 12-18-2001 11:32:26
Pulling & watching other people's awsome HP readings at max rpm. Engine falls on it's face when lugged & it wasn't all the cam's fault. Better with a carb just large enough it doesn't limit airflow too much at redline but mixes the air/fuel properly when lugged down to peak torque rpm & lower. Different carbs are built for different applications. Some even allow swapping of boosters,venturi's etc. The dyno is the only place to realy see what makes max ft lbs of torque when lugged down. If in doubt send your stock carb & cam to Roberts & tell him what you plan to do with them. He'll send back what is required. Before getting to wild on HP concentrate on getting traction 1st. No use spinning out in 2nd gear just to watch someone else putting past you in 1st gear.
Nn No No....
12-19-2001 05:49:10
 Re: Re: Re: Re: Burns in reply to G Taylor , 12-18-2001 19:45:58
I was asking about YOUR knowledge. You gave some sound advice. I'm wondering what you have done to prove it. Have you had different carb on a dyno? Maybe you're just got an idea that sounds good and you haven't proved it.
G Taylor
12-19-2001 10:25:01
 Re: Re: Re: Re: Re: Burns in reply to Nn No No...., 12-19-2001 05:49:10
How many tractors,carbs & dyno pulls will be enough to qualify?
One would be plenty.........
12-19-2001 14:01:21
 Re: Re: Re: Re: Re: Re: Burns in reply to G Taylor , 12-19-2001 10:25:01
You made a good point about the venturi size. Then you say you gained this info from watching other tractors. That tells me you concept sounds good but might not be true. Have you dyno any tractors with a small venturi and then a big venturi? If so how did they compare. I would also question if that one type of carb would act the same as all the other carbs.
G Taylor
12-19-2001 16:04:10
 Re: Re: Re: Re: Re: Re: Re: Burns in reply to One would be plenty........., 12-19-2001 14:01:21
How about posting your name & address? I didn't say one type of carb is the same as others. The same laws of physics & fluid dynamics apply however.
Sooooo
12-19-2001 19:06:45
 Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to G Taylor , 12-19-2001 16:04:10
You get on here and say a bunch of BS. You can't prove it. You never tested it. The only thing you have to go by is that you "watched other tractors". Do you see why we get tired of your answers. They sound good but they are wrong and you can't prove them. I see why you and burns are butt buddies.
_-_-_-_-_-_-___-__-_-_-_-
12-19-2001 19:34:05
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to Sooooo, 12-19-2001 19:06:45
Jacka$$ like you make pulling not fun and talking about it.
burns
12-19-2001 19:27:55
What is the proof that he is wrong? You certainly must have data from your own tests to back up you claims of G Taylor being wrong.
Do all of us a favor before you start typing a bunch of NOTHING? Share with us your experiences, tractors that you have built, or a reference to your vast knowledge of engine design and testing.
I know for a fact that you CAN'T but instead will twist someones words around or fabricate more NOTHING.
JOhn
12-19-2001 19:40:01
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to burns, 12-19-2001 19:27:55
just, I saw the tractor on the dyno, and watched him switch the carbs. He's my cousin. so, watch how you put things, and realize your not always right.
John
burns
12-19-2001 19:45:39
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to JOhn, 12-19-2001 19:40:01
Easy friend,
My comments are not directed to you or your cousin. My questions are directed at the hidding Osama bin tractor expert.
Burns
G Taylor
12-19-2001 20:14:38
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to burns, 12-19-2001 19:45:39
Well Burns, these snivelling little whiners are not so bad. They make a person appreciate the people who are good natured & well adjusted. The following real world experience for the spineless coward hiding in the dark always ready to criticize others so he doesn't feel so small. If you must know we had the carbs off the 50,60 & 70 for cleaning after some twit(s) filled the fuel tanks with soil & corn cobs at the Blyth show. Likely done by a relative of yours who also doesn't own a tractor. We swapped carbs around for fun between the 50 & 70 around to see what would happen. Pretty much text book, the 70 was strangled on the top end & leaned out but would pull down farther/smoother to the last putt with more torque at the stall point. The 50 gained a couple of HP at redline but bogged when lugged down to the last putt. Deere also swapped metering internals for gas or allfuel applications but kept the same throttle body & venturi. Done the same on street/race cars. Some one always showed up with a 750 or 850cfm carb on a modestly warmed over smallblock.We'll stick an old spare 600 vacuum secondary on there & throttle response goes from bogging to snappy. The slight loss on top end is more than made with increased torque from idle to past peak torque rpm. Less plug fouling & fuel consumption too. Now that we have moved onto fuel injection it's pretty much a mute point. Still some goofs who pull the fuel injection off & install a carb & wonders why the car goes slower & burns more fuel however.
Oh Yea
12-21-2001 13:19:38
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to G Taylor , 12-19-2001 20:14:38
You should call your overpriced buddies at Roberts carb repair. Ask them what they do to their pulling carbs. They machine the venturi area bigger, and drill the jets out. They get more power at ALL rpms. Makes your story sound like BS.
G Taylor
12-22-2001 17:40:41
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Burns in reply to Oh Yea, 12-21-2001 13:19:38
So how are things at Denny's these days anyways?
John
12-20-2001 11:38:00
Thanks, and I see what your saying. I saw it with an A.
John
12-19-2001 19:16:58
He may not be ablle to prove it from his own personal experiences, but I see what he means, plus have YOU tested any of these things to say they aren't true? so, speak for yourself calling someone a liar, and I have some info I have gotten from other pullers, like my cousin that put a G carb on an A and it made NO difference in HP. I have a friend who did the same and swithced back to the A carb and said that he just used more fuel with the G carb. THis guy ain't no fool either. If you have anything else to say, my email is [email protected] or you can post it for everyone else to see and maybe you will get made a fool of too like to did that other guy.
John
Jerry B
12-14-2001 07:15:54
Well said. That is why I think a lot of pullers are disapointed with their tractors after doing a lot of work to them and then hanging on a carb that would feed a 1000 cube engine. They are so over carburated it is a wonder the engine runs as well as it does.
Jerry B
12-13-2001 06:30:17
The venturi is a built in restriction that increases the airspeed as the air has to "sqeeze" through the narrow passage of the venturi. As the air speed increases it can not turn as abrutley and therefore does not flow back out of the air stream to touch the sides of the venturi just past the smallest part. Since no air is touching that area, this creates a vaccume. This vaccume draws gas up the jet tube and into the area of the vaccume. Because the gas is moving quickly when it leaves the tube, the gas contiues to travel until it incounters the upward moving airstream and is then drawn along with the air into the cylinder.
With out a venturi there would be no vaccume to draw fuel into the air stream. The only way to get fuel into the engine then would be under pressure from a pump. (fuel injection)
Increasing the cross section the runners to increase airflow requires you to increase the venturi by the same proportion. If left small the venturi will add too much restriction and negate most of the porting efforts.
farmall flogger
12-13-2001 05:17:56
I think the main principal of the venturi being smaller is to keep the velocity of the airflow up. If you're making the port bigger the venturi probably needs to be bigger too. Hope this helps.
burns
12-12-2001 21:03:25
Being that I am not an carb "expert", I can only offer my thoughts. Most of the porting that goes on in the shops are either to help with the airflow for your fairly stock engines and then there are the folks who are feeding big cube engines. Obviously if you are feeding the big cubes with big valves, ports than the carburetor needs either changed or modified. I am not sure what brand tractor you have but there are a lot carb rebuilders that could give you more detailed answers.
Roberts Carb in Spencer Iowa specializes in Deere Motec Engineering has an excellent reputation for quality work.
