information on massey harris propane heads
jd80
06-10-2004 20:54:44
would like to know if there are any differences between a gasoline head and a lp-gas head on the massey harris 44 or 444.
JD2830
06-11-2004 05:16:18
 Re: information on massey harris propane heads in reply to jd80, 06-10-2004 20:54:44
The gas and lp heads are 2 different part numbers so the combustion chambers would be different I have 1 of each but the propane is still on motor so I am not sure how much different they are.
Masseypuller
06-12-2004 06:03:46
 Re: Re: information on massey harris propane heads in reply to JD2830, 06-11-2004 05:16:18
The propane and gas heads have different (assembly) part numbers because of the Stellite exhaust valves in the propane heads. I have seen the interior configuration of both the gas and propane heads and there is no difference (in the castings). The propane engines DID have higher compression ratios, but it was done with piston domes.
Regards,
Masseypuller
jd80
06-14-2004 13:56:11
 Re: Re: Re: information on massey harris propane h in reply to Masseypuller, 06-12-2004 06:03:46
thanks for the info masseypuller
jd80
06-11-2004 14:36:01
JD2830 could you provide the propane part number
