ChadS
06-11-2004 06:35:07
Re: Puller motor leaking in reply to Mack, 06-10-2004 20:12:20
I had that problem as well, I tried everything but replace the sleeve, or junk the block. Well, it does leak a bit still but I did slow it down, I used JB weld at the bottom of the sleeve, and honed it out,, The piston did not come into contact with the JB weld, it held for a while, now if it sits for a week, I have water in the oil, only when it sits, not while it runs,, There are sevral good sealers out there, one to recommend is not a name brand sealer,, it is called Sodium silicate, or egg preserver, it is the same stuff in the name brand sealers, but a bit cheaper,, and you buy it at the drug store, another option with out repair, or sealers, is to replace the water in the radiator, with engine oil then all tha happens is that you get oil in the oil when it leaks. Sounds scary?? Naa, oil has a very good cooling effect though a radiator, since it is a puller, it does not run all day long, and wont get hot, unless it did before,, works for me,, Just my opinion,, ChadS
