Qs 4 Chads
mike
06-10-2004 08:36:42
will this chevy curve kit work in my 880 oliver???if so what do you mean about lighter spring in the kit....thanks chads
ChadS
06-10-2004 12:44:01
 Re: Qs 4 Chads in reply to mike, 06-10-2004 08:36:42
Yes. It will work for any tractor distributor that has a mechanical advance in them, which is basicly most makes and models. In the chevy recurve kits, there is 3 sets of springs, for different rpm curve settings. The lightest set, and the second lightest springs in the kits, will work in them. What this does is it speeds up the distributors ability to do its job, control timing during rpm changes. It does not affect the number of degrees of timing, just the speed in which it reacts. And in cases where these smaller parts are forgotten in tuning for performance, and not just tractors, race engines, well any thing!,,, you have a more of a sluggish throttle responce when you give it the gas. Whne you open up that throttle, that governor tells the carb to open, cause we are going all ahead full!! The distributor then should sence the sudden rpm change, and change timing precicely, at the climbing rpm. On most stockers,, the distributor does nothing but rotate, and fired the plugs. This is an engine control device it does more than just fire the plugs. In performance pulling,, you need the engine controls to be fine tuned, Reaction times in control devices on engines, is where the fine tuning begins. CHadS
