Stock Shootout: Which Tractor is Best?
Mopower
06-08-2004 06:45:16
I often compare similar tractors of different brands. I would like to know FROM THE FACTORY, which of the following similar size tractors would have been the best pullers. Did I leave any out? This should be interesting to see what people have to say.
Massey 44
Deere A
Moline U
Farmall M
Case DC (?)
Oliver 88
264ss
06-09-2004 19:09:46
 Re: Stock Shootout: Which Tractor is Best? in reply to Mopower, 06-08-2004 06:45:16
moline U
farmall M
oliver 88
JD A
case DC
massey 44
A.P.
06-08-2004 16:55:37
I think you should make a change to your list. I do not think the U belongs, it should be a UB. As far as the JD A, until they added the creeper gear it didn't have enough power in factory stock condition. For a work tractor from the factory I would give the nod to the 88. It came stock with indenpendant PTO, live hydraulics and the best seat suspension of the group.
If you want the tractor for pulling, any of them will perform quite well in warmed up condition.
My $.02
A.P.
a puller
06-08-2004 16:38:55
I would say the the order would be
ollie 88
MMU
massy 44, then the JD A.
I often wanted to try a case L or a wd allis for pullin..may not be in the same "class" but is good canadates I believe.
Redman
06-08-2004 13:45:15
the 88 hands down.
Don
06-08-2004 12:13:11
i dunno guys my dad has an M that has the slow low in it with 16.9 38's it shows 43 horse on the dyno and it pulled #12,500 and spun idlin down 10% on rpms thats it it dont do ne thing in around 5000 with the low gear but u get up into 7500 and you cant touch it
Toot
06-08-2004 11:09:52
If you want to get technical, a JD G is rated with the other tractors you have listed instead of the A.
Krouthead
06-08-2004 08:03:40
Deutz PS 65, hands down best puller from the factory! Thats what i pull and it is stockbore stroke cam!! A whoppin 325 CI pulling ,competing with and even beating tractors with twice the cubes!!Only modification is more fuel,via fuel screw,no pump mods
These tractors do come from the factory with limited slip too.Although my personal preference is this sometimes hurts more than helps
My 2 cents ....Been on a missionary trip in the congo.
Reverend Krout
Antique New York Deutz pu
06-08-2004 17:26:01
 Re: Re: Stock Shootout: Which Tractor is Best? in reply to Krouthead, 06-08-2004 08:03:40
Welcome back Krout. I trust you are well after your trip and I hope you found what you were after. Did you happen to stop in South America on your way back? I got a whole truck load of those PS 65's {3} and hope to get a puller done soon. Later John
Krouthead
06-08-2004 17:37:59
 Re: Re: Re: Stock Shootout: Which Tractor is Best? in reply to Antique New York Deutz pu, 06-08-2004 17:26:01
Hey Big John! Yeah stopped in Argentinia found what i believe is a factory V8 diesel, 8L514 the tag shows to be a 1953!!! It has factory duels,pretty heavy though,trying to make shipping arrangements now!!Ill let ya know!! I hear you got a surprise in the makins!!??
Take care,save me some fresh cabbage!
Krout
olivertractorgirl
06-08-2004 07:42:51
Oliver 88 = best
Massey 44
Moline U
Mopower
06-08-2004 08:43:20
 Re: Re: Stock Shootout: Which Tractor is Best? in reply to olivertractorgirl, 06-08-2004 07:42:51
Hey Olivertractorgirl, there is a nice lady that pulls a tough Oliver 88 with us (Clintonia Pullers). Is it you?
G-MAN
06-08-2004 07:39:39
In pure stock form, Toot is correct. That creeper gear is nearly impossible to beat, particularly at heavier weights. That's why you see "A"s and "60"s pulling clear up to 10,000 pounds and more in dead weight pulls. Try that with any of the others.
DCTOM
06-08-2004 07:22:20
MASSY 44
CASE DC
MM U
OLI 88
FARM M J D A
ChadS
06-08-2004 07:56:21
 Re: Re: Stock Shootout: Which Tractor is Best? in reply to DCTOM, 06-08-2004 07:22:20
Hey Tom,, Ol Budd dont have that creeper gear in that A does he?? LOL!! How did ya do at Westville? ChadS
Toot
06-08-2004 07:27:54
If youre talking about the latest year models of each:
JD A (has creeper gear-will not run out of power)
Massey 44
Case DC
MM U
Oliver 88
IH M
I have had one of every thing you listed, and pulled them all in stock form. I cannot be convinced otherwise.
steveormary
06-08-2004 09:32:41
 Re: Re: Re: Stock Shootout: Which Tractor is Best? in reply to Toot, 06-08-2004 07:27:54
How about a plowing demonstration. Hitch them to a 3-14 plow and see how well they pull.
steve
Ollie Puller 2
06-08-2004 13:08:43
 Re: Re: Re: Re: Stock Shootout: Which Tractor is B in reply to steveormary, 06-08-2004 09:32:41
Now do you know which tractor is best???
steveormary
06-08-2004 14:30:34
 Re: Re: Re: Re: Re: Stock Shootout: Which Tractor in reply to Ollie Puller 2, 06-08-2004 13:08:43
Ollie Puller 2;
No,I dont know which is best. I would favor the Massey 44 and the MM U. I have not operated a DC Case or A John Deere and never could figure out how to shift a Oliver. Well,ya,all have fun with your pulls.
steve
Ollie Puller 2
06-08-2004 14:42:40
 Re: Re: Re: Re: Re: Re: Stock Shootout: Which Trac in reply to steveormary, 06-08-2004 14:30:34
My son and I have a Oliver 88 and a Super 88 and we do pretty good. Good luck on your decesion. They all pull good with a little tweaking.
