how big MM (or any) rod journals
IN puller
06-06-2004 20:41:55
how big should I have my rod journals? I am wanting an 8" stroke and is very tight? 2.?
want this tractor to hold for a few seasons.
CASEPOWER
06-06-2004 22:21:04
 Re: how big MM (or any) rod journals in reply to IN puller, 06-06-2004 20:41:55
How much compression? How heavy weight class? How many RPM's?? How many mains in the engine? Is the crank welded and ground? or just offset ground? Lots to figure! Thats why a Briggs can run a inch journal, but a small block chevy cant.
Jerry
06-07-2004 06:05:56
 Re: Re: how big MM (or any) rod journals in reply to CASEPOWER, 06-06-2004 22:21:04
I know where there is an 8 inch crank. Never used. It won't pass the cam. It probably could be bought. Its for a U crankcase.
06-07-2004 09:39:10
 Re: Re: Re: how big MM (or any) rod journals in reply to Jerry, 06-07-2004 06:05:56
how much does he want for it? any contact info? thansk alot. the tractor will have about 10:1 or so compression, ummm4232 heads, big bore, stock cam for right now. welded and reground. thanks alot.
