tire pressure
Spuds
06-06-2004 16:43:17
Pulling in 4500 lb class with uncut new 13.6 stones what tire pressure is idel? Im new to pulling and think I've been BS. I started at 10 psi did a full pull but about spun out,a track officeal said to drop 1.5 pounds. why did I listen spun out just after I started to go. Sucks being the NEWBE!!!
Spuds
keith
06-07-2004 05:42:19
 Re: tire pressure in reply to Spuds, 06-06-2004 16:43:17
Hey Spuds,
I am not a seasoned professional either but We just put on the same tire on an 11 inch wide pressed steel wheel on a WC Allis. We were running about 8 PSI and it hooked up very well. It is really going to have to be a trial and error procees to find out what is best. This will vary with temperature, and track condition. It would probably be good to go to a "fun pull" where you can just keep hooking and adjusting pressure to see what works best. Try to keep a record of track conditions and air pressure so you will know what to do each time you go to a pull.
