Betting someone here has the answer.
Loren
06-06-2004 15:43:41
I'm running out of gas on the top end and am positive the carb inlet is the culprit. What is the hole diameter in the needle seat on a 77 Standard sposed to be? No # tag I can find and thought maybe it's a 66 carb on there. Loren
andy
06-06-2004 17:44:49
 Re: Betting someone here has the answer. in reply to Loren, 06-06-2004 15:43:41
drill the hole a little larger in the needle valve and then re set your float, and maybe even raise it some. Had the same problem and that worked for me.
