lots of power what tires?
Potter
06-05-2004 15:13:23
I pull in 3500 class and I have a lot of power should I use 12.4 or 13.6 tires on a power track? I have not pulled this tractor yet help
buickanddeere
06-07-2004 09:15:27
 Re: lots of power what tires? in reply to Potter, 06-05-2004 15:13:23
Tall and narrow tires with the same ground contact area as a short wide tire, will pull more.
ChadS
06-06-2004 07:31:52
I like the 15.5 firestones, just depends on what the rules say you can run. The 13.6 will be a taller tire over the 12.4, gives you ground speed. I also use a rim that is 1 inch wider than the OEM spec on the tire on farm stocks, and 3 inches wider for mods. a 15.5, on a 16 inch rim is a great set up in my opinion, What r u pulling???? ChadS
