O/T another Ford 5.0 question
Jonathan
06-04-2004 19:06:40
I have a 1977 Mustang II with a 5.0 V8, the horsepower rating is only 140hp. Why was the Horsepower output so poor?, I know there was a gas shortage during that time, so I'm thinking in an attempt to get fuel economy, they slashed the horsepower output and put a cam in it that probably resembled a pencil, and a 2bbl carb. I'd like to create some horsepower, would I be better off to start out with a different engine out of a newer car?.
thanks in advance!.
Buzzman72
06-06-2004 09:24:57
 Re: O/T another Ford 5.0 question in reply to Jonathan, 06-04-2004 19:06:40
Wtih the mid-'70's 302, you've got poor performance from (a) low compression, (b)2.-something rear-end gears, and (c) pollution-control systems that were still being experimented with by the auto manufacturers. To wake up that 302, my recommendations would include: (1) the kit from Crane Cams that converts your block to run roller tappets, so that you can take advantage of the better hydraulic roller cam profiles that became available in the '80's; (2) a compression increase that takes you from what's probably around 7.5:1 to about 8.5 or 9.0:1...either pistons or heads, your choice; (3) a cam that provides you with good low- and mid-range power (say, up to 4000/4500 rpm), since nobody REALLY turns 8 grand on the street these days; (4) a good 4-barrel carb and intake, primatrily because it's old-tech and easier to get right "out-of-the-box" than an EFI conversion; (5) and rear-end gears in the vicinity of 3.27:1, which is what FoMoCo put in the mid-'80's LTD LX's...which were meant to be econo-size police cruisers with 5.0 HO CFI engines and AOD trannys. While an AOD tranny upgrade, as well as an 8.8-inch rear end, would also be logical upgrades, check about what flywheel it takes to make that work...I seem to recall that the AOD required a late ('82-up) flywheel, which only works with '82-up 302's with the one-piece rear main seal...but not sure of the specifics of that.
Just some ideas that might help...also, for the street, keep header primary diameters around 1-1/2" to 1-5/8" to keep exhaust velocity up, and consider a crossover pipe like Ford did themselves with the mid-80's and later Mustangs.
Jonathan
06-06-2004 18:24:38
 Re: Re: O/T another Ford 5.0 question in reply to Buzzman72, 06-06-2004 09:24:57
Wow thanks for in info!. The car has a 4spd and a Ford 9" rear end under it. I think the 9" rear is original, because it looks like it has been there for the life of the car. I have no clue why such a heavy duty rear end was used for just 140 stinking horsepower, but thats whats in it, so I have an excellent start for building a car with some power. I already have a daily driver mustang, and this one I thought I'd use as a track vehicle to have some fun.
Thanks alot!.
More than just a cam
06-05-2004 07:44:18
All car companies took steps to make their cars more fuel efficent starting in the early 70's. This usually involved lower compression ratios, poor flowing heads, small cams, and low ratio gearing. Buying a newer/older engine may not be any better than what you have. You have to find out the specifics of what you are buying and what you want to spend. A crate motor is probably the easiest way to go and will set you back from $3000 up.
ChadS
06-06-2004 07:26:23
 Re: Re: O/T another Ford 5.0 question in reply to More than just a cam, 06-05-2004 07:44:18
Granted, that is the gospel. Also, just like the gas wars, insurance companies were also charging outragous prices for high performance cars then too. Just because they had a big engine in them. So they made them with less HP, better milage, and lower insurance. If an engine swap is justified over building one, I like the later model 5.0 HO. 86-93 mustang, T-bird, cougars. Take off the fuel injection, put a nice 650 holley mechanical 4 bbl, and hold on to your seat!! These later engines have roller cams in them, and that is a huge difference over the flat tappet cam engines. One time, I had a 80 mustang that I had put in a 410 ci small block chevy in it,, Dont do that though lol,, but was lots of fun,, at the strip, the inspection crew said,,, "That is the darnest thing I ever seen" It looked really good between the shock towers. LOL All it took was a S-10 V8 conversion kit, and change the yoke on the drive shaft to adapt the chevy tranny. Went racin!! It used the original shifter linkage, tranny crossmember, the rest was GM. Anyways,, In most cases older is better for HP engines without doing alot to them,, but the new stuff is cool too! ChadS
