flat head versus cyclone head
JD-G
06-02-2004 08:19:13
How much of a difference is there regarding horsepower between using a flat head for a JD G versus a shaved cyclone head down to the top of eyebrow on intake valve? Money being the factor, would the shaved head be a good way to go?
yes
06-02-2004 17:48:14
 Re: flat head versus cyclone head in reply to JD-G, 06-02-2004 08:19:13
shaved style head might give you slightly more power but definitely will give you more torque over the flat head.
j
06-02-2004 09:29:56
if it had the same compression ratio, it would have more with the cyclone, but since you can't get it too easy, the flat head makes up the compression and gains you 5hp.
