8 JD A
DARIN
06-01-2004 14:57:55
I am in the process of putting together an A engine. found an 8" crank, using std. bore 70 gas
pistons in a sleeved block. the crank has std 3"
rod journal. Am i going to run into rod length issues? want to use regular model A rod. thanks darin.
j
06-02-2004 09:32:26
 Re: 8 JD A in reply to DARIN, 06-01-2004 14:57:55
your gonna run into rod/cam problems more then length...
