Its BROKE
Tyler
06-01-2004 07:11:53
I tore the engine down yesterday on that old 70 and found a huge crack that ran almost completley around the #1 journal. It looks as if it started to go up into the weld also. What gave it away was a bad scrape in my rod insert. So I went to the crank to see what could have made such a mark and there it was. Now for the big QUESTION, Where do I find a crank with less than 2 weeks till our first points pull? 9.5 CRANK
Tyler
06-02-2004 10:56:12
 Re: Its BROKE in reply to Tyler, 06-01-2004 07:11:53
Sombody could buy this right now with or without the crank. Ill put it back together or you can.Im thinking of restoring an unstyled G . If sombody want to do some tradin let me know .
Ty
06-02-2004 11:43:15
 Re: Re: Its BROKE in reply to Tyler, 06-02-2004 10:56:12
no overseas buyers or scammers
-john
06-02-2004 11:35:55
I am interested for the right money, email me your phone number and a price.
Tyler
06-02-2004 11:41:31
 Re: Re: Re: Its BROKE in reply to -john, 06-02-2004 11:35:55
Wont seem to let me do that . Are you a scammer ?
john
06-02-2004 13:38:12
 Re: Re: Re: Re: Its BROKE in reply to Tyler, 06-02-2004 11:41:31
no..not taht I know of...I am interested in the tractor, but depending on the price I don't know if I can afford it. [email protected]
Earl S.
06-02-2004 08:42:01
Tyler, The only chance you have making that kind of stroke to last is a 3/8 to 1/2 in radius in the crank.Has to be real smooth. Narrowed rod.Relieved brg to match radius. How long did that crank last????Was it balanced ?? Earl In Illinois
Tyler
06-02-2004 10:53:05
 Re: Re: Its BROKE in reply to Earl S., 06-02-2004 08:42:01
3 years
or billet
06-02-2004 16:23:32
 Re: Re: Re: Its BROKE in reply to Tyler, 06-02-2004 10:53:05
or get someone to make a billet one for you, then it'll hold no problema.
Drew
06-01-2004 19:23:04
Campbell Crankshaft in Kansas City could probably do one that quick for you. It won't be cheap ($1400ish for a 9.500"), but it will be good quality. This is the same shop that Schooler uses. Hope this helps.
Super Lurker
06-01-2004 09:00:12
You could call Schooler or Merfield or even Jerry's Welding to see what they might have laying around.(All their numbers are in the Hook.) If they can't help or someone on this board can't give anymore leads to one, then your pretty much SOL. Hope it all comes together for you, but it's about slim and none on getting one that large that quick. You JD pullers need all the luck you can get.
George T.
06-01-2004 18:52:19
 Re: Re: Its BROKE in reply to Super Lurker, 06-01-2004 09:00:12
Try POLK equiptment at New Paris, In. They usualy have a large selection of used JD parts.
Mopower
06-01-2004 08:34:53
I still got one in an old junk 70 engine but have not had time to tear it down.
Ooops!
06-01-2004 08:42:58
 Re: Re: Its BROKE in reply to Mopower, 06-01-2004 08:34:53
My mistake. I assumed an OLIVER 70. I read your earlier messages. Duh...9.5" Oliver 70? I should have guessed not. Good luck on your John Deere Tyler! I don't happen to have one of those laying around unfortunately.
