Farmall M Valves
Walter
05-29-2004 21:36:01
I have a 440 CID Farmall M engine and was wondering if anyone has a good suggestion for a vavle size that will help my performance. i have a 450 gas head ported and polised. I've been looking at some 396 GM valves, they are close. I would like to know what you guys are doing.
Thanks.
ChadS
05-30-2004 07:43:56
 Re: Farmall M Valves in reply to Walter, 05-29-2004 21:36:01
There are a few other things you can do with out changing the valves, and see a differerence. What have you done to the ignition, governor, and carb? these 3 items, in basic stock form, or even slightly modified will hide power, and throttle response. How much compression in the cyls, and what rpm do you run? ChadS
Walter
05-30-2004 10:05:07
 Re: Re: Farmall M Valves in reply to ChadS, 05-30-2004 07:43:56
I have 235Psi on cyl. 2000 rpm.
What can I do to the govenor to make it better?
