Oil pump
oliver guy
05-26-2004 18:30:28
i am building a oliver to pull and wanted to know if there is a way to get higher oil pressure. can you get to high of oil pressure?
Thanks
TimC
05-27-2004 14:12:19
 Re: Oil pump in reply to oliver guy, 05-26-2004 18:30:28
Check to see if the pump has an overpressure bypass. You should see a small piston and spring held in place by a roll pin or something. If so shim the back side of the spring .060 and along with new bearings it should have more than enough.
You don't need to go to high, it would put unnecessary stress on the cam.
25 is plenty. 45 is plenty for higher rpms (i.e. 3 or 4 thousand).
oliver guy
05-26-2004 18:31:34
i forgot to say this is a oliver 88 thanks
