starter for ub
minnie ub
05-26-2004 17:51:35
under stand that there might be some one in nebraska that builds a starter for a moline that has a few extra horses. not sure of the state. ours likes to eat starters for breakfast.
Captainhookerus
05-27-2004 19:44:32
 Re: starter for ub in reply to minnie ub, 05-26-2004 17:51:35
I guess the most important things are to have timing and fuel set so engine will start instantly. Then make sure battery is at full charge with big short cables. Setscrew starters with initeria starter drives are poor at best. The best thing I ever did was to use a 5 Star crankcase and then get a 3 bolt flange mount starter. At least the drive is engaged in flywheel before current is applied to starter motor which helps. A lot of compression and to much timing will get the best of combinations.
