Rear weight placement for John Deere A
Dave
05-26-2004 16:10:42
Where is the best place to hang rear weights on a John Deere A for pulling, I am constructing mounts to hang suitcase weights and would like some imput on this such as height, distance from axle, in front or behind, etc. Thanks in advance.
52 A Boy
05-27-2004 15:07:16
 Re: Rear weight placement for John Deere A in reply to Dave, 05-26-2004 16:10:42
I pull a 52 JD A and my rear brackets will hold 14 105lb IH weights, its about 14in long and 4.5in wide, my middle bracket will hold 5 weights on each side its 10in long on each side, then on my front bracket its 11ft from the center of the rear axle and will hold 7 weights.
Hope this helps.
52 A Boy
05-27-2004 15:08:59
 Re: Re: Rear weight placement for John Deere A in reply to 52 A Boy, 05-27-2004 15:07:16
Forgot, my rear bracket is bolted in the holes on the axle.
TROUBLE
05-26-2004 18:11:02
Last couple years i pulled a 36 A in 4500-5500 antique and i just had short brackets on both sides of the axle.300 eash side in frount, 600 each side in back . the rest on the belly .I coulda used more on the back.Dads going to run it this year so ill try some more stuff this year.
Bamapuller
05-26-2004 19:20:54
 Re: Re: Rear weight placement for John Deere A in reply to TROUBLE, 05-26-2004 18:11:02
If your running cut tires you will need more on the front and as far out as your rules allow.
