Multi-disk clutch
Joshua
05-24-2004 18:14:33
Can anyone tell me the best way to add a 2 or 3 disk-clutch to a 460 Farmall. Must you modify the input-shaft to the trans. What brand clutch is widely used. Thanks for the help.
Redman
05-24-2004 19:49:43
 Re: Multi-disk clutch in reply to Joshua, 05-24-2004 18:14:33
2 disc should fit without any modification,you might have to grind a little out of the top of the clutch housing(i think that was a 3 disc though).
try some of the tractor pulling webs like mother inlaws garage,they have a classified section.
a 2 disc should be steel as they add a bunch of heat and the cast don't like it too much.
you could also have a machine shop make one with a copy of your old one,just add a floater plate and another disc.
Hillbilly Hooker
05-25-2004 21:00:34
 Re: Re: Multi-disk clutch in reply to Redman, 05-24-2004 19:49:43
Heads up! I just clicked on the motherinlaws Garage and went to one of their links and got zapped with a virus. H.H.
Redman
05-26-2004 14:37:00
 Re: Re: Re: Multi-disk clutch in reply to Hillbilly Hooker, 05-25-2004 21:00:34
really!?i guess i won't be going there for awhile.
