RUNNING OUT OF FUEL?
MIKE
05-20-2004 08:03:57
LAST WEEKEND WAS THE FIRST TIME I PULLED MY 880 AFTER ALL MY MOTOR WAS DONE, I WAS PULLING 6500 CLASS IN 5 GEAR, THE GOVERNER JERK AND JERK THE TRACTOR 3/4 THE WAY DOWN THE TRACK, AS SOON AS THE TRACTOR STARTED DO LUG, IT RAN OUT OF FUEL, IT HAS DENNYS MOD CARB, 3/8 LINE WITH FREE FLOW FILTER. SOMEONE SAT I JUST NEED A FUEL PUMP..WHAT IS THOUGHTS....THANKS.....
FARMALL
05-21-2004 06:25:21
 Re: RUNNING OUT OF FUEL? in reply to MIKE, 05-20-2004 08:03:57
Get it right the first time! I guess that isn't true now is it? Serves you right for using Dennys for anything.
mike
05-21-2004 08:07:36
 Re: Re: RUNNING OUT OF FUEL? in reply to FARMALL, 05-21-2004 06:25:21
i thank all of you from your info, im going to put the pump in this weekend, it is a 5-7 psi is the to much????
ChadS
05-21-2004 04:52:17
Look at the spark plugs when it does that, if they are whiteish in color, not enough fuel, black, too much fuel. I have to run a fuel pump on a stock 263 IH 6 cyl, it will suck the carb bowl dry, wont keep up by gravity feed alone. Fuel pump will help, you may have to open up the needle seat a bit like previosly mentioned to get the proper fuel flow to the main jet and the metering stem. 5th gear at 6500?? Sounds like a monster!! ChadS
Mopower
05-21-2004 04:48:20
Sort of embarrassing huh. I was running my M-M in 5500/1st gear when it would die in the middle of the track. Died in a parade once too. I cleaned my tank, went to a sediment bulb instead of the contraption I had, soaked the carb, and bent my float valve a little. I could lug it all day after that. It was quite a klunker. New big engine coming now. I think you are right...get a pump and try it. 5th gear in 6500?! Gosh dang fella! I'd love to see that. 880 is a sweet lookin machine.
buickanddeere
05-20-2004 20:55:23
What is the diameter of the orfice in the needle/seat of the carb float bowl? Maybe all you need to do is mix and match a larger set in?
Paul
05-20-2004 19:56:17
I was running my 88 on the dyno two days ago and noticed a dip in output and found the carb was running out of fuel. this is on a 65 horse engine. I think youare going to need a sizable fuel pump.Also it is abad idea to run high compression engines without enough fuel things have a tendancy to melt when run lean.Paul
Earl S.
05-20-2004 08:51:35
You have to look at the needle and seat, thats what controls the fuel in the bowl. Is it the stock 880 carb modified? If venturi is too large in relation to the throttle plate you won't have any btm end power.Email if you need help. Earl In Illinois
MIKE
05-20-2004 09:01:05
 Re: Re: RUNNING OUT OF FUEL? in reply to Earl S., 05-20-2004 08:51:35
I TOLD DENNY I HAVE A 1650 MANFOLD, SO I THINK IT WOULD BE A 1650 CARB, IT IS TWICE THE SIZE OF THE 880 STOCK CARB..
Super Lurker
05-20-2004 08:26:50
I think if you can run 6500 in 5th gear, you need alot more than a 3/8 free flow to feed that super sized Denny's carb.
MIKE
05-20-2004 08:32:06
 Re: Re: RUNNING OUT OF FUEL? in reply to Super Lurker, 05-20-2004 08:26:50
I GAVE DENNY MY CI. WHEN HE WAS BUILDING MY CARB, AND ITS ONLY TAPPED WITH 3/8 INSERT BARB...
