Hey ChadS
Jon
05-19-2004 04:10:18
A while back I talked to you about a limited slip for a super88/880 well the first pull of the year we broke 3 teeth off the pinion gears. With a limited slip setup would that repalce the pinion gears altogether? What has to be taken out or put in so you can put the limited slip in? Thanks Jon
ChadS
05-19-2004 06:07:58
 Re: Hey ChadS in reply to Jon, 05-19-2004 04:10:18
You have to remove the pinion shafts, and the pig, or differential carrier, Send me the one brake disk, preferrably a new one, both brake pinion shafts, and the carrier, or pig.And a brake cover. Our kits do not affect any bearing tolerances,, or gear to gear lash in the spiders, that all stays stock, the kit is easy to install, it goes together, as you reassemble the tractor. Give Earl a call, at 574-893-7437 for info on the differentials, 7 days a week, till 9pm. Chad
