Starter Help
Tyler
05-15-2004 20:33:31
I need a bigger and better way to start my tractor rather than useing a log chain. The AR11159R starter just aint cuttin it. Has anyone tried to put a bigger starter on a JD 70 gas? Mine is around 745ci and Im having trouble trying to find a starter that will fit in that small area under the crankcase. Please Help! THANX TYLER
ChadS
05-16-2004 05:35:17
 Re: Starter Help in reply to Tyler, 05-15-2004 20:33:31
Can those be converted to the top mount starter? Did you ever find out if it would work? maybe hook up 2 12v batteries, and some very large battery cables going to the starter, I have seen on my H, when I used the smaller cables, when I hit the starter button, the cable will actually jump around!! And it would barely crank the engine, Changed the cables to bigger size, it does turn over alot better, 726ci 70 JD? HMMM,, That will be a strong puller !! Hope this helps,, ChadS
Tyler
05-16-2004 10:03:30
 Re: Re: Starter Help in reply to ChadS, 05-16-2004 05:35:17
Chads, I do have the 70 diesel conversion plate to mount the starter on the top side. However, the top side of the crankcase is very thin and Im afraid it will crack. I think Denso makes a starter that will fit on the bottom, but Im not sure which one to use. Maybe sombody has a part number or some other thoughts on this . Thanx TYLER
Tyler
05-16-2004 10:30:11
 Re: Re: Re: Starter Help in reply to Tyler, 05-16-2004 10:03:30
I forgot to say I dont have petcocks either. I just now got it runnin good and I really dont wanna take it apart to do this.
TOM
05-19-2004 13:26:37
 Re: Re: Re: Re: Starter Help in reply to Tyler, 05-16-2004 10:30:11
TRY A DENO STARTER OFF NEW DEERES 7810 8000S OR SO THANKS TOM WORKS GOOD ON BIG CUBES JD G TRACTORS
