70 John Deere Gas puller
Jack
12-06-2001 10:41:46
Under a load my 70 don't black smoke a bit and it does not have the 50 hp that it is supposed to either.Would removing the oil pressure operated fuel assembly and putting on a big filter and big hose help me get more fuel?The carb set screw does not help the hp much.Would sending the carb off help and if so who is the best on a duplex carb?Thanks
Gman
12-08-2001 00:05:25
 Re: 70 John Deere Gas puller in reply to Jack, 12-06-2001 10:41:46
Jack---Roberts Carb Service fixed a DLTX-51 for my "G-Max." big cubes and runs fine little smoke idling and under load very little smoke,I run three turns open on load jet. Roberts email is www.robertscarbrepair.com or ph.#712-262-5311.Later Gman
al
12-07-2001 08:27:31
One trick is to knock the web that seperates the 2 cyl inside the intake manifold.They say a big difference.Try an electric fuel pump to see it is getting enough fuel.I know a guy running a 70 head on a stoked G whom said he HAD to do this.
al
