Need Info on oliver 88 parts
brent
12-06-2001 07:48:04
I was wondering if anybody knew where i could get me some custom pistons for my 88 oliver and i also need to find a place to get me cutom rods made also. please reply if you know a place that does good work. thanks
Annie Seaberg
02-19-2008 13:23:13
 Re: Need Info on oliver 88 parts in reply to brent, 12-06-2001 07:48:04
I need information on where I can buy a grill for an 88 Oliver to finish my restoration project before spring.
Jerry B
12-07-2001 06:40:12
Cunningham Rods built mine and they cost almost $1400 by the time I go them back.
Any custom piston manufacturer can custom build you a set of pistons to your specs. I would send them a sample piston and pin as close to what you want as possible along with a detailed drawing/explanation of the modifications you require. This will determine the actual cost.
One place I spoke with wanted a "Bondo casting" of the chamber so they could configure the dome on the piston. Sounded like a good idea to me.
bigmotors
12-09-2001 02:23:21
 Re: Re: Need Info on oliver 88 parts in reply to Jerry B, 12-07-2001 06:40:12
Try to find a off the shelf piston. It will save you alot of money. Mopar, Ford, Chevy, big block pistons work good. It depends on what bore you looking for as well. 4.250 to 4.500 you should have no problem. When you start talking inch pin height, and special dome, yah-go with a custom piston. J.E. and Ross have always been good for me, but get out your christmas money! Last set cost me $920.00 for 8. About $102.00 to $115.00 a piston, for that size.
Good Luck.
