Stock ??
Chuck M
05-09-2004 15:42:53
would a 264 block in a M still be called stock? I know it came with a 248. is it ok anywhere?
DANNYH
05-11-2004 14:59:58
 Re: Stock ?? in reply to Chuck M, 05-09-2004 15:42:53
WE HAVE THE SAME STUPID RULE IN OUR CLUBAND I HAVE NEVER UNDERSTOOD THE LOGIC BEHIND IT . WE CAIN'T EVEN RUN A 264 IN A 450 FARMALL I'M TOLD BUT HAVE NEVER CHALENGED IT. IT JUST MAKES THE PULLERS OF THE M'S BORE THE BLOCK AND PUT IN THE 281 KIT . WHICH IS WHAT MOST ARE RUNNING OR 298 WITH NO SLEVE . MOST OF THE ALLIS AND OLIVER AND FOR THAT MATER THE FORDS A RUNNING A NON OEM ENGINE , I GUESS IT'S NOT WRITTEN ON THE SIDE OF THE BLOCK LIKE THE FARMALL . I STILL SAY THIS A LAME RULE AND SHOULD BE DONE AWAY WITH . IF IT BOLTS TO THE BELL HOUSING AND NO ALTERATIONS ARE REQUIRED ELSE WHERE IT SHOULD BE CONSIDERED LEGAL IN THE STOCK CLASSES. MY 2 CENTS WORTH. DANNY H SR
WILDMAN
05-12-2004 05:18:11
 Re: Re: Stock ?? in reply to DANNYH, 05-11-2004 14:59:58
DR AMEN!THEY DO HAVE SOME DIFFERANT RULES.
m puller
05-10-2004 21:02:07
why is it natpa wont alow a 264 block in div 2 i h M...really not much differance then boring the 248 out...tell me why natpa ????? ??
ChadS
05-11-2004 06:58:53
 Re: Re: Stock ?? in reply to m puller, 05-10-2004 21:02:07
is that right??? NATPA will not allow the 264 block in the M? (div 2?) who in their right mind came up with that one? ChadS
ChadS
05-10-2004 05:09:50
Most clubs will allow an upgraded engine. Providing it is a direct bolt in with no alterations. Read your rules, see if they say that M can use 450, H-350, JD can use power blocks, AC WC-WD use D-17 and the list can go on and on. Chad
colekicker
05-09-2004 23:02:27
Depends on your rules.
Don
05-09-2004 19:57:42
264 block is stamped on the outside of the block. It is easy to tell if the motor has been changed.
Jason
05-09-2004 17:30:37
Who is going to know its a 264 unless they tore it apart? I don't think it would make much of a differnce if boring it out would be the only change you did.
Flyin Farmall
05-09-2004 16:16:01
If you are in a pure-stock class,it would be ok if it can pass the dyno,but most rules do say original engine.
Glen E.
05-11-2004 18:43:19
 Re: Re: Stock ?? in reply to Flyin Farmall, 05-09-2004 16:16:01
I thought stock meant just that, STOCK!!!!! Our rules say all tractors must be stock, with only minimal overbore (less than 0.125), just like it came from the factory. Factory RPM's, factory carb, factory wheels, No added performance items, and no items removed to gain a weight advantage. If you want to alter the tractor, then there are pulls for modified tractors.
Chuck M
05-11-2004 06:40:42
its double edge sword when told put the money, inside the motor not the outside.
