John Deere H Puller
John Carter
05-09-2004 15:09:31
I need to know all the power secrets for a Deere H. I have been told that you could get 40+ Hp from an H. I want to pull it in the 2500-3500# classes.
Oliver puller
05-25-2004 12:38:49
 Re: John Deere H Puller in reply to John Carter, 05-09-2004 15:09:31
john deere are just junk you shouldn't be able to pull. They sound like they're going to blow up.You guys with your gay 2 cylinders.
John
05-25-2004 16:13:05
 Re: Re: John Deere H Puller in reply to Oliver puller, 05-25-2004 12:38:49
I have a Oliver 88 as well as 2 John Deere H's. THe deeres have more power per cubic inch than the oliver. but your not real bright then are you.
Mopower
05-10-2004 04:39:24
I have some info on parts for an H. I pulled a stock 1939 model. Very weak, but tons of fun!!! The cam gear has to be modified if there is too much power. I do know that the later cam gears were stronger than the earlier ones. There is a fella that makes a custom one. I will try to find the info. E-mail me if you'd like at [email protected]
John Carter
05-11-2004 15:15:20
 Re: Re: John Deere H Puller in reply to Mopower, 05-10-2004 04:39:24
If you have time please send me any info that you can to hop up my H.
ChadS
05-10-2004 05:12:56
We have a JD H pulling in our deadweight club. it is a stocker, but it runs nice. Deadweight pulling, you could run it just the way it is and be competitive over a hot rod tractor! Is that right? the cam drives the whole thing? Wow... Chad
Mopower
05-10-2004 06:57:21
 Re: Re: Re: John Deere H Puller in reply to ChadS, 05-10-2004 05:12:56
I did respectable in deadweight because it is balanced well and has taller tires. I was able to beat less experienced pullers because of how I hooked up to the sled, but I rarely came in the top four. Just didn't have the grunt at 14 h.p. If it had just 5-10 more h.p., it would be tough to beat. Someday..... Not bad for a tractor that Dad and Grandpa bought for $75 (adding only paint).
Dan
05-09-2004 21:35:49
I built one with 3 7/8 and stroke it 3/4 inch. Goes well in classes with ac c,b int a,b and other tractors like these.
shotgun
05-09-2004 20:10:42
saying round here is a 420 will eat H lunch
Orin K
05-09-2004 15:28:36
You have to remember that the H puts it's power to the ground through the camshaft, and it will only stand so much power.
Jeremy Brault
05-10-2004 12:45:32
 Re: Re: John Deere H Puller in reply to Orin K, 05-09-2004 15:28:36
There is a guy round here that has a b crank in one
does very well, but my AC Wc eats it for lunch.
