strongest M Farmall
maco
05-09-2004 14:38:33
I always liked M farmalls. I like the stock appearing ones the best. I was wondering who has the strongest in your area. One that comes to mine is Eldon Walk from central Il. He pulls 7500# 2nd gear, stock RPMs. Who has the srongest stock RPM tractor in your area?
ChadS
05-11-2004 06:55:53
 Re: strongest M Farmall in reply to maco, 05-09-2004 14:38:33
Dont forget about Brad Zeck's Wild Child Farmall M, not the strongest out there, but it does run strong. rpm is in left field, but, an honerable mention. ChadS
Greengo
05-14-2004 00:33:06
 Re: Re: strongest M Farmall in reply to ChadS, 05-11-2004 06:55:53
I can remember pulling at Young America, Indiana
at Zeck's farm in the late sixties or early
seventies. They were always tough.
what?
05-12-2004 10:30:26
what do you mean by left field?
ChadS
05-13-2004 07:17:47
 Re: Re: Re: strongest M Farmall in reply to what?, 05-12-2004 10:30:26
Little on the high side, but aint complaining about him one bit! Always love to see him pull down in Princeton In. He has some ground speed! Chad
colekicker
05-09-2004 23:11:40
A lot of it depends on the sled. The sled we have in Burton, Texas is so hard out of the hole, you are pulling hard to get it moving. My SM hasn't ever lost power, but sure as heck has lost traction.
Cody
05-09-2004 19:05:42
Elmer Glass for Dickson,TN has one of the strongest if not the srongest M in the country, 4th gear in the 7000-7500! 2nd high on the 9spd in the 5500!
Timmy
05-09-2004 20:58:36
 Re: Re: strongest M Farmall in reply to Cody, 05-09-2004 19:05:42
Paul Marlatt probably has the strongest M in the country, although Jared Beduhn's is close!
FB
05-10-2004 14:55:35
 Re: Re: Re: strongest M Farmall in reply to Timmy, 05-09-2004 20:58:36
i would say marlett DEFINITLY has the stronget i heard 200+
DANNYH
05-13-2004 18:57:49
 Re: Re: Re: Re: strongest M Farmall in reply to FB, 05-10-2004 14:55:35
200 HP THRU A "M" HEAD????? ??? I'M NOT SO SURE ABOUT ALL THESE BIG NUMBERS THAT ARE OFTEN TALKED ABOUT . I KNOW PAUL M.AND HAVE PURCHASED SOME STUFF FROM HIM . I NEVER SEEN HIS TRACTOR PULL BUT I'M SURE IT IS A REALY STRONG M FARMALL. I HAVE A MOLINE THAT DYNOS @ 167 HONEST H.P.AND IT PULLS 4TH 12-13 MPH IN 7700 LBS AND IT HAS ALL IT WANTS AND IN FACT IT HAS POWERED OUT A FEW TIMES ON A SUPER GOOD TRACK WITH THE BOX TOPPED OUT ON A 27,000 LB TRANSFER SLED. YET I SEE SOME OF THESE SO CALLED 200 + H.P. TRACTORS POWER OUT AT 5700 AND 6700 LBS AT 12-13 MPH. I THINK SOME OF THESE GUYS HAVE , HIGH PERFORMANCE DYNOS AND ARE CAUSING FALSE HOPE AMONG OTHERS . I KNOW ONE WHO CLAIMS 212 HP OUT OF 466 CID M. THAT'S ONLY 2.19 CUBIC INCHES PER HORSE POWER THRU LITTLE PORTS AND SMALL VALVES FIRING EVERY 90 DEGREES OF CRANK ROTATION. I'M FROM SOUTH CAROLINA NOT MISSOURI BUT YOU WILL STILL HAVE TO SHOW ME . PERSONALLY I THINK ONE WILL NEED A AIR COMPRESSOR DEVISE OR SOMETHING BESIDES GASOLINE TO ACHEIVE THAT KIND OF YIELD. I DON'T MEAN TO MAKE ANYONE MAD AND NOT MAKING ANY ACCUSATIONS BUT I'VE NEVER BEEN ABLE TO EVEN COME CLOSE TO THAT KIND OF EFFICENCY AND 200 + H.P. IS A WHOLE LOT OF HORSE POWER WITHOUT A TURBO. MY 2 CENTS WORTH ON BIG H.P. NUMBERS DANNY H SR
ChadS
05-14-2004 05:50:45
 Re: Re: Re: Re: Re: strongest M Farmall in reply to DANNYH, 05-13-2004 18:57:49
Well said. ChadS
Cody
05-10-2004 15:53:26
200+? He must have a titanim pto shaft in it to hold that kind of HP! He is stout none the less.
