WD-45 Pulling Hitch
Dennis
12-05-2001 17:22:02
I am going to try my hand at Farm Stock pulling this coming summer. I have a '55 WD-45 narrow front, with 14.9 x 28 tires. It runs very strong, but I need to come up with a hitch. There is a height and distance from axle requirement. Most of the ones I have seen are original hitches that have been cut off and had a three inch ring welded on. I have an old three point conversion hitch that snaps into the coupler bell and is connected to the lift arms with chains. My question is, can I use the Traction Boost System to my advandage with this hitch? If so, I can add my allowable weight to the front end, and gain my back wheel weight with the sleds weight being transferred. This is my first tractor, and I know very little about pulling. This is probably a crazy idea, but it sounds good to a beginner like me. I would appreciate any insight from the experts. NTPA is the ruling body around where I live.I plan to pull at the county fairs in my area.I live in central Indiana. Thanks in advance. Dennis
ken
12-07-2001 17:48:28
 Re: WD-45 Pulling Hitch in reply to Dennis, 12-05-2001 17:22:02
most rules say you must have a fix hitch
Jim (Mi)
12-06-2001 07:39:45
I think the traction boost system raises up under load to keep from stalling. This could get you DQ if you were already at the max height.
