560 Lp Head
Ohio M Puller
05-07-2004 05:44:46
Question to those that have knowledgeable answers, is there a difference in the 560 LP head and the standard 560 Gas head? I have the access to one and didn't know if it would help out someone that needs one for pulling? Thanks in advance to those that help.
Ohio M Puller
supermpuller4
05-07-2004 09:19:17
 Re: 560 Lp Head in reply to Ohio M Puller, 05-07-2004 05:44:46
I looked at a 560 LP head at a swap meet and their was no difference between standard and LP head.
Mike
05-07-2004 06:02:49
That head increases compression combined with LP intake will increase HP.
ChadS
05-07-2004 06:19:28
 Re: Re: 560 Lp Head in reply to Mike, 05-07-2004 06:02:49
OMP, I tore a 560 lp apart, it has high domed factory pistons to make the compression change in the engine, yes, the intakes are a bit larger, ports on the head are the same, the heads are the same casting in the compression chamber. look in the I&T shop manual for the 460-560, the compression difference is 20 psi difference between the gas, and lp models, the difference is in the pistons. If you want to see a 6 cyl head that will make power, have a look at the truck heads, darn near flat in the chamber!! I have one too,, LOL. They are so small of a chamber, that dome pistons can not be used, only flat tops. Hope this helps, Chad
