Hey Casepower, got a couple of DC questions.....
Screamin DC
05-06-2004 20:32:07
Decided to go 6.5 on stroke. I know clearance is the next issue and was wondering how it would fit in with the block and cam. I know I'll probably have to notch the cam but how much? Also, do you know of any sources for ten thousandths undersize main bearings? Thanks.
joecool#1
05-09-2004 06:47:17
 Re: Hey Casepower, got a couple of DC questions... in reply to Screamin DC, 05-06-2004 20:32:07
who stroked the crank? i am wanting to build one myself.
Don L.
05-09-2004 05:05:45
I can supply rebabbited semi finished mains, will have to line-bore in the block to size.
Don L.
Travis
05-07-2004 11:08:29
No disrespect to anyone else on here, but listen to Mel and use any advice he gives you, he helped me build a big cube DC and it runs pretty good
mEl
05-07-2004 12:07:43
 Re: Re: Hey Casepower, got a couple of DC question in reply to Travis, 05-07-2004 11:08:29
Travis, thanks, lots of trial and error, so far having a great start to the season, engine strong,Pulled third gear with D sprockets in 4500 consistently last year, the ideas you and I talked about in the head in place and working! Long time no hear from!! mEl
Travis
05-08-2004 09:45:24
 Re: Re: Re: Hey Casepower, got a couple of DC ques in reply to mEl, 05-07-2004 12:07:43
Are DC was running good, until the block around the rear main and the back of the motor cracked, have to set up a new block again.
mEl
05-07-2004 04:59:20
My first engine was a 6.5 stroker, pretty easy but there are a couple things you MUST know, the oil hole in the crank is very close to the surface and if you grind to the original width you will grind into the drilling on the underside of the throw. Must narrow rod on the oil hole side about .300 should be ok, drop the rod bolt 3/8 on the cam side and a slight knotch on the cam and it rolls right through. I melted the babbit out of the stock rods and had them machined to MT JD rod shells. that and a 4 5/8 bore makes a nice combo. Will help you get a parts list together if you like. mEl
