350 Farmall wrist pin size
JB
05-06-2004 18:59:09
Will a 350 rod work on my H pistons? In other words is a 350 wrist pin the same size as my H wrist pins or can a modification be made to adapt the H rod to work with the 350 wrist pin?
ChadS
05-06-2004 19:02:50
 Re: 350 Farmall wrist pin size in reply to JB, 05-06-2004 18:59:09
yes and no, use the 350 rod, and the h bushing, or go get a set of 350 pistons, with the small pin, and use H rods and offset the wrist pin higher on the rod, then machine the piston for TDC clearence. Great economical HP gain for IH engines. ChadS
JB
05-06-2004 20:00:48
 Re: Re: 350 Farmall wrist pin size in reply to ChadS, 05-06-2004 19:02:50
Chad, Will the 350 pistons fit the Farmall H block without boring out the block? Thanks for your response. JB
ChadS
05-07-2004 08:42:42
 Re: Re: Re: 350 Farmall wrist pin size in reply to JB, 05-06-2004 20:00:48
yep, if it has thick wall sleeves in it to start with. Pull out the sleeves, hone them. Chad
