300-350 400-450 Gas or Propane Heads
Kenny Chinsey
05-05-2004 09:38:05
Can you run domed pistons on an H or M with either propane head or gas head? I am thinking about a 450 gas head for my M puller but it has domed pistons and I didn't know if the valves would hit. I am also building my H for pulling and it also has domed pistons.
trkr
05-06-2004 18:28:49
 Re: 300-350 400-450 Gas or Propane Heads in reply to Kenny Chinsey, 05-05-2004 09:38:05
Used to put modeling clay on top of piston and clamp it all together and check.
Broke 'n' Dumb
05-06-2004 07:38:52
yeah...nice screen name...
Crooks Gunn
05-06-2004 06:08:10
Nice name....
Ol Gray A
05-05-2004 15:43:46
I may be wrong but I thought that the exhaust valve was open on the exhaust stroke.
Wide Front SM Puller
05-05-2004 14:38:29
 Re: 300-350 400-450 Gas or Heads in reply to Kenny Chinsey, 05-05-2004 09:38:05
I ran a 450 lp head on my Super m with IH "firecrater pistons" We figured the tapping noise was a bad lifter until the valve seat on #3 broke and crushed the piston. The pistons were hitting the valves all along. I went with M&W "add power" piston with 1/8" lower dome and everything has been good to go.
DANNYH
05-05-2004 13:43:40
YOU DON'T HAVE TO WORRY ABOUT THE VALVES HITTING THE TOP OF THE PISTON AS THERE IS NEVER A VALVE OFF IT'S SEAT WHEN THE PISTON IS AT TDC. DR SR
Kenny Chinsey
05-05-2004 20:44:28
 Re: Re: 300-350 400-450 Gas or Propane Heads in reply to DANNYH, 05-05-2004 13:43:40
You do have to worry if the dome is taller than an IH Firecrater, which ours is. Thanks guys.
ChadS
05-06-2004 06:52:36
 Re: Re: Re: 300-350 400-450 Gas or Propane Heads in reply to Kenny Chinsey, 05-05-2004 20:44:28
I can tell you this much,, My cousin has a M, we built 2 years ago, he put an LP head on it, it has 4 in M&W high domed pistons, stock head gasket, no clearence problems at all, but this is just one tractor wih one type of pistons, may not work for all of em, Chad
ChadS
05-07-2004 08:40:50
 Re: Re: Re: Re: Re: 300-350 400-450 Gas or Propan in reply to redcub, 05-06-2004 20:37:43
70 hp. it was 57 with an 8060 head before. It has the carb, governor, and ignition work done, I would say that with just putting on the head, it would be in the mid 60's for HP, no work done to any thing, just the head. has 185psi of compression. Good combo if you aske me, LP head N M&Ws! Chad
