Farmall with truck plug question
colekicker
05-03-2004 13:48:51
Ok, I heard about using the #4130 truck plugs but I have a concern. The way that the 4130 seals off is with a taper into the head. The C87 AC plugs I have been running seal with a washer. What must be done to run the truck plugs? Should a special washer be made? I am curious about what to do for the set to work. Any help would be appreciated.
TDK
05-03-2004 22:01:27
 Re: Farmall with truck plug question in reply to colekicker, 05-03-2004 13:48:51
You can buy an adapter for plugs. Try www.ream products.com
ChadS
05-04-2004 06:42:33
 Re: Re: Farmall with truck plug question in reply to TDK, 05-03-2004 22:01:27
I have ran them with and with out the gaskets on the plugs. Now, I have had no trouble with the plugs sealing in the head, no oil dripping, on anything, I used the gaskets from an AC plug (C-87) But, I did not like them at all because of them smashing the gaskets in a differnt style edge on the plugs, so I ran them with out, no leaks, That is my experience with the 4130 plugs. I have a good hot ignition, and a good fuel that is a cleaner burning fuel, so less contaminates to rob power. Chad
