SPARK PLUGS
Hillbilly Hooke
05-02-2004 20:22:22
What is everybodys choice for sparkplugs? I have been running Autolights in a Moline. I am having trouble with them misfiring. Give me your opinions please. H.H.
39H PULLER
05-03-2004 20:18:47
 Re: SPARK PLUGS in reply to Hillbilly Hooker, 05-02-2004 20:22:22
NGK HR5 Nice hot plug
Wide Front SM Puller
05-03-2004 18:28:29
Do you think some of the Mississippi Mafia have tinkered with your tractor? I know some were thought to have tinkered with a certain black tractor down in Louisiana last year.
You just can't trust anyone these days.
WFSMP
Hillbilly Hooker
05-03-2004 20:43:54
 Re: Re: SPARK PLUGS in reply to Wide Front SM Puller, 05-03-2004 18:28:29
Wide front, thats why I run those side shields to prevent sabotage ha ha. Did yall get to go to Dresden Saturday? See yall soon. H.H.
05-04-2004 04:03:28
 Re: Re: Re: SPARK PLUGS in reply to Hillbilly , 05-03-2004 20:43:54
Dad and I did not make it, but the Mafia's newest edition won the 6250 KOH on it's first time down the track. Jerry Smallwood's Super M took the $500. Look like we may have to change the name of our club.
I thought the side shields on your tractor were to hide the nitrous bottle and turbo?
WFSMP
zig
05-03-2004 15:28:32
Are you sure its the plugs
Hillybilly Hookee
05-03-2004 20:50:09
 Re: Re: SPARK PLUGS in reply to zig, 05-03-2004 15:28:32
Yes, there are several of my fellow pullers are having the same problem with the autolights. We have used them in the past successfully. The repair shop where we buy them ordered a case of them and has had the same problem with most of them. You can chang them out and they run fine for a few hours and then they begin to break down. Must have been a bad batch. H.H.
Two-Tone
05-03-2004 14:22:12
Hooker; try Bosch raceing plugs. you should be able to get them through O'Rilley Are you coming next weekend?
tt
Hillbilly Hooker
05-03-2004 20:40:59
 Re: Re: SPARK PLUGS in reply to Two-Tone, 05-03-2004 14:22:12
Where? Lincoln, Yes Were planning on coming there on the 15th. Where you been? I thought you musta Passed, havent heard from you. H.H.
IH H Puller
05-03-2004 09:10:14
I run champion 4130. I have no complaints and no missing.
colekicker
05-04-2004 00:10:44
 Re: Re: SPARK PLUGS in reply to IH H Puller, 05-03-2004 09:10:14
How do you run the 4130? The 4130 is a taper seal and the stock fit with a washer. Do you use an adapter? I thought the plug was the same diameter. Please educate me.
ChadS
05-04-2004 06:44:57
 Re: Re: Re: SPARK PLUGS in reply to colekicker, 05-04-2004 00:10:44
same threads on the plug, instead of a 7/8 socket you will now use a 13/16 socket, which is good for the IH 6 cyl!! ran them with, and without gaskets, had no problems, dont overtighten them!! Chad
ChadS
05-04-2004 08:28:28
 Re: Re: Re: Re: Re: SPARK PLUGS in reply to redcub, 05-04-2004 07:58:15
4130 champion
ChadS
05-05-2004 06:07:31
 Re: Re: Re: Re: Re: Re: Re: SPARK PLUGS in reply to redcub, 05-04-2004 18:15:56
No, Just put them in and go. indexing would work on a plug that has a short electrode plug, and is hiding the flame kernal from the plug. With the 4130, they move the electrode closer in to the cyl away from the head casting. it is unshrouded. Chad
