ford 901
Gus
05-01-2004 19:28:14
I have a ford 901 that I would like to pull. I don't know to much about them. I know they turn alot of rpms. I have talked to a couple of people and they told me that this tractor was not made until 1958. And the tractor club has a limit on the year 1957. Will I be wasting time biulding this type of tractor? Or will I have a good runner? Please give me some advice.
Hot Rod Ford
05-02-2004 11:43:52
 Re: ford 901 in reply to Gus , 05-01-2004 19:28:14
Gus,
The 901 series began production in 1958 starting with serial no. 11977. They were built through 1962. If your club requirement is 1957 or older I would say you are out of luck. I own a 1955 Ford
700 and worked it over four years ago. I have pulled Dead Weight dirt, Dead Weight cement and Transfer Sled and have won trophies in everyone. In fact I had over 150 trophies on the shelf and I gave majority of them away. Too much dusting! A Ford hi-clearance can make a very competitive puller in the 3500 to 4500 pound classes. The 4000 pound class has been best for me. If you could find a 900 series, that would get you under the age requirement in your club. The 900 and 901 mechanically are nearly the same but the 901 has some refinement in the styling.
Hope this helps.
CASEPOWER
05-02-2004 16:51:02
 Re: Re: ford 901 in reply to Hot Rod Ford, 05-02-2004 11:43:52
Can you e-mail me or post your e-mail address?? Couple of questions for you. [email protected]
