Part # for pertronix kit for 70 JD.
James
04-26-2004 15:34:15
I am going to try getting a pertonix kit for my 70 John Deere at my local parts store. Does anyone have the number for the kit? I have "the needed information" that Denny's needs when ordering one but I bet I could get it much cheaper here local.
buickanddeere
04-26-2004 19:57:00
 Re: Part # for pertronix kit for 70 JD. in reply to James, 04-26-2004 15:34:15
For the 50,60 and 70 gas and all-fuel engine whose distributers turn at crank speed with the wasted spark on the exhaust stroke. The 1111558 mag mount distributer uses the 1121 for 12V neg ground and 1121P12 for pos ground.40511 for the Pertronics 3.0 ohm coil or 40011 for the 1.5 ohm coil. Either coil works in the ignitor system. Using a ballast resitor is still an topic for debate. The Ignitor II and 0.6 ohm coil is not available for the two cylinders at the moment.
