Dekalb Super Pull
Stroker G
04-22-2004 21:00:06
Hey COATPA officals,
Whats up with the results?
Mark D
04-26-2004 09:15:49
 Re: Dekalb Super Pull in reply to Stroker G, 04-22-2004 21:00:06
Hey, where's the div5 Nat. asp. results?
JUNKYARD DOG
04-23-2004 16:50:13
THERE POSTED AT COATPA SITE
D.H.
04-23-2004 12:07:12
And your question is what ?
Very disappointed
04-24-2004 00:19:57
 Re: Re: Dekalb Super Pull in reply to D.H., 04-23-2004 12:07:12
The question is how come the distances are all mixed up for the winners. Because ,for example in the div. 2 4500# they added weight to the transfer in the middle of the class. There were around 6 full pulls so they dedided to take the top 2 from each heat. Bad part was the 6 who pulled a lighter load got to come back and pull again. They seemed to forget that after the top 4 or so the rest of the class pulls for pride. By adding weight the second half of the class got thourly hosed. Some of the full pulls who came back in the pulloff,[ the setting for the pulloff was the same as the second half of the class] didn't go as far as some who pulled the heavier load in the first round but ended up placing ahead of the later pullers just because the had full pulls.I say forget this heat stuff and let the luck of the draw work its way. And NEVER-NEVER change the transfer in the middle of a class. When the class is over I want to know how i compared to the whole class.
Stroker G
04-23-2004 18:04:33
It's the results of the pull. You did read the question.
D.H.
04-25-2004 12:33:21
 Re: Re: Re: Dekalb Super Pull in reply to Stroker G , 04-23-2004 18:04:33
Yes I read your question ,but I wanted to know what exactly you were wanting to know.Let's assume you had not seen them [they are on the site now],you didnt understand them [they start at the top of each class with 1st place then work there way down to last place],the heats sucked I bet they try somthing different next time [I hope].Give me some help if this didn't anser your question.
Stroker G
04-26-2004 09:02:58
 Re: Re: Re: Re: Dekalb Super Pull in reply to D.H., 04-25-2004 12:33:21
Hey D.H.,
To answer your question. Yes, I do know how to read them. Yes, I do know where they were posted. And to fully understand my first posting look at the time and date of it and you look at the time and date of when they put the results up. My question was 12 hours before the result came out. I was just wondering when they were posting them. Thanks D.H. for asking hope to chat at you in the future or on the track. Stroker G
D.H.
04-27-2004 07:13:51
 Re: Re: Re: Re: Re: Dekalb Super Pull in reply to Stroker G, 04-26-2004 09:02:58
Your welcome I was just trying to help because I have some questions on this heat deal that I was not pleased with.I was wondering if you had the same issue?
D.H.
04-27-2004 05:55:07
