16.9*34 tire psi
FB
04-22-2004 16:31:50
What psi does a 16.9*34 tire need to be in the 4500 to 5000
Dave
04-22-2004 19:40:28
 Re: 16.9*34 tire psi in reply to FB, 04-22-2004 16:31:50
It depends alot on track condtions (hard, soft,wet, dry, type of soil on track) age of tire, cut, uncut tire. Even the type of air quage used will make a difference (how accurate they are). A general guess would be from 8 to 14# would be a good starting point, after that, experiance. Good luck.
Jerry
04-23-2004 04:47:48
 Re: Re: 16.9*34 tire psi in reply to Dave, 04-22-2004 19:40:28
I use that size tire and I try to get the bars to sit flat on a flat surface and as many bars on the surface as possoble without having a low pressure appearance. The pressure is usually about 8 pounds. Watch your pressure in a hot sunny day. The pressure can go up as much as 2 pounds.
