WD fly wheel-heatchecks
Jordan
04-21-2004 12:10:46
I am rebuilding an WD with an M&W piston kit and WD 45 crankshaft. My clutch disc was worn to the rivets causing my flywheel to have heat checks. I have had the flywheel resurfaced at NAPA but I wondered if it will be strong enough? It still has some shallow checks in it. I would like to run a Gleaner E spring for pulling and do not want it coming apart. One of the cranks goes all the way through the facing.
Thanks, Jordan.
larry
04-22-2004 17:59:59
 Re: WD fly wheel-heatchecks in reply to Jordan, 04-21-2004 12:10:46
JORDAN IWAS TOLD M&W PISTONS WENT OUT OF BUSINESS COULD YOU TELL ME WHERE I CAN GET SOMEM7w pistons
L Hud
04-22-2004 07:39:00
If you are pulling stock or 20% over on rpm's, you should have no trouble. I have pulled one like that for years with no problems. Hope this helps.
