CEMENT PULL-Shepherd MI pull rules/classes
puller
04-20-2004 21:14:26
ok, I finally got some rules and stuff for the shepherd pull.
5000,6000,and 7000 lb classes all are 20" high and 24" from center of the axle. no jumping classes. weight bracked in front no further then 24" from front end (don't know where they came up with that rule...), and no tires bigger then a 30.5" wide.
there is a new class a 6000 limited that has the same hitch specs, but no bigger then 18x38 bias tires. and no wider then 18.4. there will be a vote to see if people want their entery fee back or not and if not, it will be payed in the prize money as well as the collections and donations from local businesses. post back if you have any questions anyone.
puller
04-22-2004 08:57:56
 Re: CEMENT PULL-Shepherd MI pull rules/classes in reply to puller, 04-20-2004 21:14:26
I asked and they said as along as they are behind the tires and won't gouge the cement. I forgot to say that it starts at 11:00 SHARP. the scales will be at the pull and they will be shut off at 10:45.
Pistol Pete
04-21-2004 07:11:05
I'm sure that they also have a rule concerning wheelie bars. They are similar to the rules for the Belding pulls. (i.e. must hit before the drawbar, stick out behind the radius of the rear tires about 4", and must support the weight of the tractor.)
