Need Allis puller parts
Keith
04-19-2004 09:04:37
Hello, We took the newly rebuilt WC to a pull on Saturday and it seems that the clutch is not going to hold the power. I wanted to see if anyone knew where I could find a better clutch. I understand that there is a 9-finger clutch that will fit. I am also in search of some 4 1/8 inch flat top pistons that will work. It has a crank from a WD 45 and rods from a WC. If anyone knows of sources for these, I would appreciate the info.
Thanks,
Keith
KBMO
04-20-2004 02:36:28
 Re: Need Allis puller parts in reply to Keith, 04-19-2004 09:04:37
Keith, I have a nearly new 9 spring pressure plate I would sell, yes if you have much motor at all the old 6 spring pressure plates will not hold. I also have a used set of 4 1/8 M&W piston and sleaves that are in good shape. I just took them out of my tractor a few months back. They would work fine with your 45 crank and WC rods. Reply if you are interested...
Keith
04-20-2004 04:39:49
 Re: Re: Need Allis puller parts in reply to KBMO, 04-20-2004 02:36:28
Hey KBMO,
I would like to talk to you about these. Please e-mail me at [email protected]. I couldn't get a link to your e-mail address.
Thanks,
Keith
Mark
04-19-2004 17:56:11
the clutch you need is a 9 spring. they are available in a 4 button or fiber disc. cant remember where I got mine but it was on the net I just started looking up clutches. 1729P sealed power piston 4 1/8 bore 2,390 comp dist but it is dished.
