wd45 propane head
larry
04-13-2004 20:01:37
is there any boost in my wd45 gas head engine if i could find a propane head to add to engine for more hp
L Hud
04-14-2004 07:27:44
 Re: wd45 propane head in reply to larry, 04-13-2004 20:01:37
Allis used the same head on propane and gas. The difference is the pistons. They put WD pistons in the 45 propane burner. This ups the compression. There is about 3 different flat top pistons you can get for it. If you really want compression use WD 8000 altitude pistons. Hope this helps.
Allis Puller
04-13-2004 21:08:45
Most propane heads just boost your compression, your tractor already has a flat head, its hard to do anything with that. Email me and I can give you some cheap build ups.
The Swami
04-13-2004 20:50:22
Nope!! Sorry!
