Farmall H
Mez25
04-12-2004 11:02:49
I am responding to you after I asked about the fuel filter mix-up on my tractor, and there was a noticeable difference when the fuel filter was on backwards and when it was placed on properly. The filter itself was only 1/4 of fuel and when i put it on right it filled up all of the way. Shouldn't this make a significant difference?
Wild Horses
04-12-2004 12:38:39
 Re: Farmall H in reply to Mez25, 04-12-2004 11:02:49
You bet it will. It's restricting the flow of fuel to the carb, starving the motor for gas when it opens up. It'll run great at idle or little trottle because it doesn't require much fuel and the line can keep up. But when you open up the throttle, the carb needs more gas faster and it's not going to get it.
