300-350 head on H = what HP?
WR
04-11-2004 12:47:32
Bought new valves and its at the machine shop having the valves ground for the 8776-DA head for my '43 Farmall H. In the meantime I came by a 300-350 head, 361479-R1. I was wondering what gains I would get by putting the 300-350 head on the H engine.
Could I use the 300-350 maifold and carb on the 8776-DA head until I know the 300-350 head is okay? Would the engine with the original head and the 300-350 mainfold and carb run okay? I have to rebuild either carb I would use, so I would just prefer to do the 300-350 carb if possible. Any gains with just themanifold and 300-350 carb?
Thanks in advance...
WIld Horses
04-12-2004 12:50:53
 Re: 300-350 head on H = what HP? in reply to WR, 04-11-2004 12:47:32
Regardless of the head you use. Put on the 350 manifold, if you have an original H manifold. I assume their like the M to 450 manifolds. The original manifolds have a block holding the exhaust & intake together. The 450 or 350 manifolds use three fins. The fin manifold will flow so much better that it will condense water above the carb. Compare the two & you'll see what I mean.
junkyard dog
04-11-2004 17:03:11
I put one together on the cheap a year ago . found a set of nos firecrater sh overbore pistons [3 9/16] fits H bare bore perfectly pd 200 for sleeves and pistonsstill in org ih box.found a 300 head same no as yours laped in the valves, used 300 man and carb , used bearings over again boy were alot of my buddies laughing at me and shakin theirt heads but it dynod 44 hp not bad imagine if I got a real valve job done and shaved it some maybe some dayhaving too much fun with it now
