How much bore/stroke for a JD A or 620
Johnny A
04-09-2004 20:58:20
How much can I bore a stock JD A or 620 block? When they are bored into the water and sleeved do they use a ring at the top of the sleeve to hold the sleeve in the block and let the bottom stick through? How thick does this sleeve have to be to survive? How much stroke can be added without haveing to grind or modify the cam? Don't mind grinding the block, just don't really want to go totally crazy. Looking for about 350 to 375 cubic inches.
buickanddeere
04-10-2004 05:17:41
 Re: How much bore/stroke for a JD A or 620 in reply to Johnny A, 04-09-2004 20:58:20
The A and 620 have very little in common to swap. The Late 47+ A's and 60's do.
mike
04-09-2004 22:45:14
If that is all the cubes you want, just put in a powerblock and you will have 382 cid on a JD A ,now this will be differnt hp than gaining that cid from the crank being stroked, if that is all you need, have the crank offset ground and get some rods made, its about the same price when your done, the power block is about a 3 or 4 hour switch out and the crank will be alot more involved, my 2 cents. A 620 should take 5 and 3/4" pistons .
