Modifying Hubs
Wild Horses
04-07-2004 10:41:02
I just picked up a set of M&W hubs for my M. I would like to modify them so they will not set the rims so wide and lose some weight in the process. This is what I was thinking.
The current outer U-bolt is about centered on the hub (lengthwise). Can I drill new holes outward from that for the other two U-bolts and cut off the end? Basically, modify it to look more like IH hubs. It should take about 3.5-4" off the length of the hub, plus put more strength closer to the wheel. Will this weaken the hub? Has anyone done this before?
Donnie
04-08-2004 07:42:43
 Re: Modifying Hubs in reply to Wild Horses, 04-07-2004 10:41:02
Exactly what your talking about, I've done to mine. I've ran them, on and off, for 3 years with no problems. Its alot of work. But it works great.
