Spark Plugs, Heat Ranges, and Pulling Engines
Mopower
04-05-2004 10:25:22
From talking to tractor pullers and other motor heads, there seems to be a misunderstanding about what a "hot" spark plug is. Some of us who didn't know better (me at one time) were mistaking what we thought meant "hot spark" for "heat range". My question is: As a motor steps up from stock to modified, what change needs to be taken in spark plugs and ignition? I was running a D21 Champion (or AC equivalent) in my stock MM U. As I increase air flow, compression, engine size, and RPM, should I use a cooler plug such as D15Y? Clue me in experts...
CASEPOWER
04-05-2004 10:36:48
 Re: Spark Plugs, Heat Ranges, and Pulling Engines in reply to Mopower, 04-05-2004 10:25:22
The best thing you can do is click on this link and read all 5 pages. Then you will know everything you need to know about plugs. My second hand info would confuse you.
Medfarm
04-05-2004 20:45:08
 Re: Re: Spark Plugs, Heat Ranges, and Pulling Engi in reply to CASEPOWER, 04-05-2004 10:36:48
Hey CP, that is a pretty good answer for a hillbilly. Grins. Ray
dctom
04-05-2004 13:59:11
VERY INTRESTING CP BUT I KNEW MOST OF THAT ALREADY DCTOM
RoyG
04-05-2004 18:51:02
 Re: Re: Re: Spark Plugs, Heat Ranges, and Pulling in reply to dctom, 04-05-2004 13:59:11
Yea, But you are old hehe
CASEPOWER
04-05-2004 21:06:15
 Re: Re: Re: Re: Spark Plugs, Heat Ranges, and Pull in reply to RoyG, 04-05-2004 18:51:02
You are too Roy HeHeHe!!!!!
