electronic ignition
Ol Gray A
04-04-2004 08:09:28
Where can I find an Electronic Ignition for a John Deere A?
Eff
04-05-2004 09:31:37
 Re: electronic ignition in reply to Ol Gray A, 04-04-2004 08:09:28
try "www.pertronix.com"
If its not listed in their online catalog, just give them a call and they will find the one for you. I had great results with them.
hth
Eff
Mr Tinker
04-05-2004 06:17:51
www.brillman.com
Give John Brillman a call. He will sell you just what you need, and nothing more, and at a fair price. May I suggest you also purchase his "HOT" coil, plug and coil wires, connectors and boots to go with the electronic ignition that he sells. He has any brand of sparkplug you may like; I use AC 87 plugs in my 'A'. Did I say fair price...he sells that plug for $2.00 each!!!
Kent
04-04-2004 20:46:56
Take a look here. Copy and paste this link:>Link
It looks like @$64.00 for conversion and @$27.00 for a coil.
SteveV
04-04-2004 17:44:27
If you have a 12 volt negative ground you can get one at www.robertscarbrepair.com and get one for $79. If you have a different set up it will cost $89. Don't forget the 40,000 volt coil for just $39.00.
Steve
jim
04-04-2004 17:39:47
OL Gray A----- -Roberts carb has them also--about $80.00 for + ground---$10.00 less for - ground---also has the pakage deal,ign.coil & electronic ignition.whoever you go with--ya need to let them know witch set up you have.----- -Good luck-Jim
Carl
04-04-2004 12:05:53
Go to tractor parts on left side of screen just above photo ads. I bought electronic ignition from there. Works great. Cost around a hundred dollars for electronic ignition and about $40 dollars for the coil.
ChadS
04-04-2004 09:49:25
Try CBS Performance, 1-800-685-1492 ad is in the HOOK. Hope this helps, Chad
Sweeper
04-04-2004 19:43:09
 Re: Re: electronic ignition in reply to ChadS, 04-04-2004 09:49:25
Sometimes ChadS gives good advice, this is one of those times.
