The A JD Puller on the tractor photos!
TN Thunder
04-02-2004 09:03:18
The A JD is catching some serious air!!!
70plowboy
04-04-2004 20:03:28
 Re: The A JD Puller on the tractor photos! in reply to TN Thunder, 04-02-2004 09:03:18
WOW I just found it looks pretty foolish to me good way to snap the front end off looks like it could go over center way faster than you could pull the clutch lever back I wouldnt want to see the aftermath of it ROD
puller
04-27-2004 14:03:34
 Re: Re: The A JD Puller on the tractor photos! in reply to 70plowboy, 04-04-2004 20:03:28
It has wheely bars!!...its a cement pull..you need the front end to rock the boat and get it moving....its ALOT funner then dirt!! will post some pictures from this year shepherd later.
